Jogle
3/4 HP pump, Franklin Control box with QD Pumptec (for 1/3 to 1 HP, 5800070100). The QD Pumptec keeps tripping. So when I turn power on, the pump runs and pressure rises for 3 seconds, then trips. I've adjusted the timer on the QD Pumptec from 30 minutes to 3 min to verify it is this part, and it does turn back on after 3 minutes and pump runs/pressure rises (3 seconds). Measured current on pump was 8.12A (and Pumptec tripped with this reading). Pump is from 1999. Voltage seemed fine, but I don't have an actual reading right now (single phase, 230V circuit); just didn't write it down.
Pressure switch is fine (just FYI; 30/50; and new), replaced starting cap (original had the button bulged out, but when removed and replaced capacitance measured same as new one). Water tank pressure was set to 28 and seems fine.
No pump cycling aside from the trip/reset (meaning no pressure related cycling), and when I removed the QD Pumptec from the circuit everything seems fine. Left amp clamp on and current stayed around (just over) 8A while I watched a full fill from 30-50(which doesn't take long at all). Measured pump resistance and it matches the chart on the Franklin control box when 475' cable factored in (500 Ft well, 475' down)
So with Pumptec QD removed, everything seems OK (so far!)...pump running again, pressure is cycling as expected...so 2 questions....
1) has anyone seen one of these just suddenly fail? Haven't seen anything with anyone talking about standard failure mode of one of these, but it is ~21 years old.
2) Could it be pointing to an issue I don't/can't see; and what could/might I look for? (so assuming it's not faulty, and is triggering for a reason)...asking as I don't want to replace and have same faults.
I know the pump is old and on last leg, just want to understand this actual issue.
