Need advice on replacing shut off valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Kevin John, Jun 13, 2018.
  1. Kevin John
    Kevin John New Member
    Jun 13, 2018
    Miami FL
    Need advice on replacing shut off valve. The issue I am having is it's not a straight pipe where I can cut off the old sweat valve with any slack left to install a new one. Any advice on this would be greatly appreciated. My dilemma is shown in the picture. Thank you in advance for any help/advice that anyone can give me.
  2. Jsmallberries
    Jsmallberries Member
    Nov 2, 2015
    Zephyrhills, Florida
    My unprofessional advice assuming it's copper, heat the pipe enough to sweat off the elbow. after it cools, clean up pipe, add new fittings.
    Kevin John likes this.
  4. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    You may be able to buy another Eastman valve and just swap out the guts.
  5. MASTERPLUMB777
    MASTERPLUMB777 In the Trades
    Aug 6, 2007
    Retired Master Plumber
    Texas
    It is a threaded on valve just get one for Iron Pipe
  6. Kevin John
    Jun 13, 2018
    Miami FL
    So you're saying it's just a matter of getting through the paint and unscrewing the old valve? I should've scratched the surface of the paint and then seen that it was iron or copper. Not a professional here just trying to help out a little old lady. I've installed compression valves before but this one baffled me, I know it's an old valve and I didn't want to delve into it without some advice and be stuck in a worse position then a little drip. Maybe swapping out the guts is an answer as well I am not sure? Probably better off just unscrewing it with a pipe wrench and hoping for the best. LOL Thank you again for your advice. It really means a lot to me!
  7. Kevin John
    Jun 13, 2018
    Miami FL
    This would seem like a simpler solution if the guts of that easily removable. I'm not a professional just trying to help out a sweet lil old lady in need.
  8. Terry
    Aug 17, 2004
    From the picture it may be a soldered on valve to copper. Scrapping some paint will tell more. If it's threaded, it would have an eight sided part behind. With the paint, it's hard to tell.
  9. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  10. Kevin John
    Jun 13, 2018
    Miami FL
    As soon as I can get in there I will definitely figure it out. I should have removed all of that paint before posting. My bad. I live and I learn. Thank you so much.
  11. Kevin John
    Jun 13, 2018
    Miami FL
    Looks like a sweat valve. Flux and map gas I assume would be what I need after removing the paint.
  12. Treeman
    Treeman Member
    Jan 29, 2010
    Michigan
  13. Kevin John
    Jun 13, 2018
    Miami FL
    Yeah unfortunately I think it's a sweat valve so paint removal, map gas and flux as well as solder for the next valve. Unless compression valves can go on steel pipes. And I'm sure they can, it's amazing the products that are out there these days. But I would rather stick with the ones I know work then some new Fango dango product LOL. Thank you for all of your help.
  14. jadnashua
    It sure looks like a threaded valve to me, but can't be 100% from the provided picture. IF it is, you'll want to use two wrenches...one on what appears to be the pipe fitting to keep from twisting the pipe, and a second one to remove the valve.
    If you can look between the valve and the elbow and see threads, you'll know. It does appear that the fitting has flats on it to allow a wrench, and those wouldn't be there if it were a soldered on valve.
  15. hj
    NOT THREADED. It is a sweat valve connected to a street 90.
  16. fullysprinklered
    fullysprinklered In the Trades
    Jun 15, 2014
    self-employed plumber-electrician doing residentia
    Georgia
    For God's sake, swap the guts! Cheap, quick, and easy.
    If you're an atheist, do it anyway and stop the madness.
Similar Threads: Need advice
Plumbing Forum, Professional & DIY Advice Remodel: need advice for adding /removing tees to existing copper drain Feb 6, 2019
Plumbing Forum, Professional & DIY Advice Need Advice: Pressure Balancing Loop vs... Jan 24, 2019
Plumbing Forum, Professional & DIY Advice Need advice on reconfiguring plumbing vents Jan 8, 2019
Plumbing Forum, Professional & DIY Advice ABS hub broke. Need advice. Dec 5, 2018
Plumbing Forum, Professional & DIY Advice Switching out the shower head, need DIY advice Nov 27, 2018
