DeRanger
Hi Pros, I’m doing a master bath reno (kitchen to follow) and looking for advice on hot/cold water manifolds. I'd be happy to pay someone local for a quick consult. The main point of my post is can I buy or should I even make a manifold with 1/2" and 3/4" barbs? Some runs are pretty long on 3/4" and I am not sure I can run 1/2" direct to everything without a full gut of the house.
I’ve got a few issues and want to do it right:
- Main shutoff valve leaks (O-ring/packing)— need to shut off at the street for any work.
- Hot water shutoff valve is leaking.
- Occasional, water drops in HW tank pan — possibly the valve, but tank is 10+ yrs old.
- HW tank pan isn’t drained to the sump.
- Noticed hot water pressure fluctuations in master bath — I suspect poor barb points or sizing.
- HW heater has a dedicated ¾” cold supply from 1” main (Img-01). Hot output is T-’ed with ¾” toward kitchen + Original master bath in one direction, and then ¾” toward Laundry + Full Bath + ½ bath the opposite direction (Img-05).
- Multiple barb sizes and materials. 1” Cold copper supply and Hot output is ¾” copper. But then ½” PEX-A barbs (shower, sinks) come off the ¾” cold supply for the HW tank, not the 1” main supply (Img-03).
- New Master bath is roughed in with ¾” hot/cold (2 sinks, 2 shower heads, future steam) but currently fed from a size-drop from ½” H & C feeds downsized probably somewhere in the soffit (Img-01).
- Planning to install manifolds with shutoff valves (Img-06), replace tank and leaking shutoff, and tie in HW pan to the sump (Img-07 & 08) — but need advice on the best way to do it and if mixing ¾” & ½” barbs is OK for manifold.
