I have one well. It is very different from yours. So if it makes sense on its own, maybe adapt some of the techniques like flooding volume, and using test strips for the chlorine and pH on the water. Also the bit about also sanitizing the piping and water heater.
Your chlorine pellet system may make this very different too. The flooding volume thing may be a useful thing to drive the sanitizing into the aquafer. You sure won't have a problem with how to get a flooding volume, given your water cisterns.
I expect to go a few years between sanitizing... but it would be symptoms-based.
Thanks again! I’m torn on whether to re-install the pellet chlorinator to help combat the iron bacteria and ferrous iron in the well. The two guys that recently worked on my well recommended against it. Their theory was that with a well as deep as mine (800’) that there was a possibility that the chlorine pellets may not make it all the way down, and could get stuck and calcify within the pipes, check valves, or even at the pump.
When my pump got “stuck”, they hoisted up sections of the PVC liner to cut through to get to the pipe couplings. At many points, there was obvious pellet calcification and buildup, so I get what they’re saying. However, one guy also said that the guy who installed the chlorinator did so incorrectly (the guy who installed it was not licensed to work on wells, as I found out later).
So, I’m wondering, if that chlorinator IS installed correctly, would there really be a risk of those pellets not getting all the way down the well, and possibly calcifying? I really think the chlorinator would help out, yet I don’t want to run any risk of damaging my pump, check valves, etc.
