Hello all. I was wanting to see if anyone had any ideas on an issue I’m having. I have a 800’ well, and had a water analysis recently done. I knew the well had high levels of Iron, and the analysis reported 1.183 mg/L. I had an Iron filter installed several months ago which uses Katalox Light (the guy who recommended and installed the filter claims Katalox Light can handle Iron at that level?).
I also had a well production test done a couple months ago, and it averaged producing 0.03 gallons per minute (roughly 50 gallons per day!). With that in mind, and having had many issues running my well dry, I had (2) 175-gallon cistern tanks installed in my mechanical room. What I’m having issues with is that the cisterns are completely covered on the inside with Iron. I’ve had to run the cisterns as empty as I can (there’s still about 6” of water in each) and vacuum the water out to suck up a good 2” of Iron that’s accumulated on the bottom. The sides of the cisterns are also stained with a dark Iron color.
So far, even with the water in the cisterns being a dark Iron color, the Iron filter seems to be filtering out any noticeable Iron smell or taste. I run a backwash every 3-5 days (the backwash typically lasts around 9 minutes, and the rapid rinse about 4 minutes) so hopefully that is adequate to clean it out?
My question is whether there is a filter that could be installed either in the cisterns, or prior to the cisterns where the well water pipe comes into the home? When I do a sample of the well water, it doesn’t have any noticeable discoloration or odor, yet when it becomes oxidized in the cisterns the Iron residue starts to form (at least that’s how I understand it?). I’m getting concerned that the Iron “sludge” will continue to accumulate, and having to vacuum it out every week or so is getting pretty old!
If you all have any insight or suggestions, I’d appreciate it!
