Looking for a new well pump-
ill look at that grundfos pump equivalent later this afternoon. I didn't know grundfos owned dab!
I did not know until just after I posted. DAB has different products, rather than rebranding Grundfos. DAB is new to me, but they clearly are a big outfit.
this is an offshoot question i guess but- is there any reason a pump would be set that low(285) in practice ?
Fear that the water level will drop. Unless there is a reason to the contrary, you would usually like to have the pump 20ft or more above the bottom to give room for sediment.
But the effort the pump exerts is overwhelmingly the lift from the water surface, and not the lift distance from the pump. The water flow resistance of the drop pipe is relatively low compared to the head due to lifting.
Ok guys - i made a serious error on the casing diameter as i am not on-site. its actually 6"ss casing! not 4" .
What do you mean by "ss"? Not stainless steel, because that would be very expensive.
Yeah, that 6 inches is a big difference. The 6 inch does call for a flow inducer for better pump life and maybe some other advantages. If your pump guy is not used to doing that, search out info. This forum is a good place to search using the search box above. You could build the flow inducer yourself if the pump guy does not do that usually.
potatowolf
Pennsylvania
6" steel casing, yeah flow inducer sounds good, they are willing to do anything themselves but i offered to help including pulling the pump etc. they just replaced the roof so its a tight schedule right now.
saw this thread on the sleeves for reference so I am trying to do as much R&D prior
https://terrylove.com/forums/index.php?threads/lets-talk-inducer-sleeves.78342/#post-570428
potatowolf
Pennsylvania
thanks for all your help and support everyone. I haven't bought the pump yet- have to look at the grundfos 1/2 hp models but i didn't know pretty much jack before i stopped here so thank you for your time and explanations thus far.
Also there is a likelihood this is all diy as they might not be able to get a pump guy.
as for the pump ive been looking at this one by dab
the s4 5/07 3 wire # 60198660 / pump end 60198612
this one by macdonald w control box
A.Y. McDonald 23050V3
grundfos 10 SQ07-240
2stupid2fixit
Active Member
Penn Forest Township, Pennsylvania
You had asked about pitfalls? Pitfall is a good term in this case. It's really obvious but some people overlook it:
Be extra careful yanking the pump up to the surface. Be very patient with it. Be sure your t handle threads all the way into your pitless top if that's the kind you have. Pull the pump up gently and take rest breaks. If the pump was coming up nicely and all of the sudden can't pass a certain point, work it GENTLY. The last thing you want is to drop the old pump down that hole beyond your reach. The bill gets super expensive to extract a pump lost in the bore by a DIY person.
Phoenix, AZ
Hey Potatowolf
If you need to replace your drop pipe, we have a product called WellHose DIY Drop Pipe. It is easier to work with and handle than any other drop pipe. Also totally non-corrosive and available in one, continuous length.
Please check it out at www.WellHose.com and call if you have any questions.
Cheers
