jparkri
I'm looking for a countdown timer that will shutdown my well pump if it runs longer than X minutes without reaching the cutoff pressure. I had a hose break overnight and the pump ran until the well was emptied. If I can set the X time to what should be a normal cycle time, I could eliminate the dry well. I already have a sensor that shuts down the pump if the well is dry but I want to prevent the dry well. I'm looking for a timer that will start when the pressure switch turns on the pump and automatically reset when the pressure switch shuts off the pump. Any suggestions?
Thanks.
Thanks.
