Leak from swivel 90 in mobile home after shower arm broke
Plumbingiscool
Colorado
So my shower arm ended up breaking (gotta love a plastic one) so I’m trying to replace it. I have a new mobile home specific shower arm like what was previously there and I almost have it fixed but the plastic drop ear 90 keeps leaking. Sometimes it’s just a drip, others it may be more of a stream. I did add a picture of the shower head set up I currently have in the shower and all the pieces I’m working with. It seems to only leak once I get the shower head onto the extension and more so at full pressure from just the cold water being fully on from what I have seen. If it’s just the shower arm or it’s the shower arm and the extension, it’s fine, it’s just when the shower head is put on so I don’t think I over tightened the 90 and broke it. I think it may be the little rubber gasket/washer since I was trying to reuse the old one but I’m not sure if that’s really what’s causing it to leak. Any ideas on how to stop it from leaking?
nancymartin
Sounds like the issue might be the old rubber gasket/washer. Try replacing it with a new one, as worn gaskets often cause leaks. Also, wrap plumber's tape (Teflon tape) around the threads for a better seal. If it still leaks, inspect the swivel 90 for cracks or damage—replacing it with a new one (preferably metal) might fix it. Tighten everything securely but avoid over-tightening
