What would you do? Silicone around shower arm drop elbow.
Mooch91
NJ
Hi all,
Looking to reinstall a shower arm in to its drop elbow. I was changing a shower head, and the shower arm loosened slightly; it needed another 1/8 of a turn to get it to tighten up and now the shower arm and head are crooked.
I'd normally have no issue taking this out, re-taping it, and re-installing it. Except when I look in to the hole in the tile at the shower arm, I see that there is a thick bead of silicone at the joint between the two. Makes me nervous, as I have no idea why there'd be silicone in there, and I don't want to undo something which could become a bigger problem behind a finished wall. The installation is original to the house, and overall the house was very well built, so I don't think this was necessarily a corner that was cut, but there is no way to really know.
What would you do? Leave it, or take it out and reinstall after removing the silicone? Any good reason why there would be a big bead of silicone around the joint?
CENTRALFL
Central, Florida
Maybe the installer's way of sealing the hole. On the installation instructions of a shower arm/head I'm about to install it mentions adding sealant in the hole or else water damage may occur. So maybe they were just following that advice. That, plus it can't hurt to seal out any steamy water vapor.
Granted, I feel it's assumed no water will typically be hitting the tile above or at the shower head level so it's typically not sealed in the few that I've seen.
