Billy_Bob
- Messages
- 419
- Reaction score
- 0
- Points
- 0
I want to install a large 4" vent pipe up through a 2 x 4 stud wall top plate and then up through the roof...
The wall in question is an outside bearing wall.
But code says you can only cut a 40% hole in a bearing wall. I assume this also means the top plates of a bearing wall?
Anyway what to do?
Can I go 4" through the roof, then Y or T in the attic to 2 or 3 smaller vent pipes which would then go through the top plate in 2 or 3 separate holes?
This is my house and I am doing all the work, so I can do what I want. So for example I have the option of adding a second 2 x 4 wall in front of the existing wall so I would then have a 2 x 8 wall and could drill holes between the two 2 x 4 top plates. Or whatever will work...
Anyway what to do?
