Kitchen sink slow drain
I would tend toward the first one, based on Yelp.
Both are good with BBB.
Here is a tip. Don't be afraid to leave a message. A one- or two-man shop can do good work without an office staff.
Bucknut
Reach4,
Thank you for your reply. I went with your suggestion and chose "Dayton Sewer & Drain." On Dec 16, 2022, the employee corrected the slow kitchen-drain issue; he used a 110-Volt portable handheld plumbing snake auger (with the general purpose tool attached to the cable).
The receipt states "30 ft normal stoppage", so I assume he needed 30 ft of snake. He said the root cause was soap grease.
Unfortunately, the drain is starting to backup again -- and the 30-day warranty expired 53 days ago. I'm not sure how to proceed. Any suggestions would be greatly appreciated. Thanks.
Is this kitchen over a basement?
Does the drain pipe go down thru the basement into the basement floor?
How about a photo under the sink that shows the drains and the entry into the wall.
Also, if there is a vent pipe over the kitchen, somebody could rod down that while you run water in the kitchen sink. If your roof is steep, that would be harder. A look into the attic for the vent path could be interesting.
Bucknut
Reach4, per your request, please see photo below taken under the sink:
The reason I had asked for the photo is to see if there was going to be a way to snake the drain while water was running.
If you have somebody snake from the roof because there is a vent right above, then they could use a bigger snake, and you could run water. Much better than a 1/4 inch snake from under the sink.
For DIY snaking, take a look at Ridgid Powerspin Plus. https://terrylove.com/forums/index.php?threads/trouble-snaking-bathtub-drain.95143/#post-684357
With my lavatory drain, snaking thru the trap, there was no problem running water. Your layout does not seem to offer that as a possibility.
I expect we already established that the drain pipe was not accessible from below. I am picturing that you put a shallow tub under your drain stuff to catch spillage, pull the trap, and snake thru the opening. You hope the snake goes down, rather than up. A 1/4 inch snake is not likely to fully clean the path, but maybe expect to do that occasionally.
That disposal sure looks vintage.
Some people temporarily rework the piping under sink putting a wye in and 45 ing up to allow water to run. Ive got a pressure washer type jetter Ive only used it on yard drains , though Im an experianced plumber I steer clear of drain clearing except my own and a few jobs I dont know all the tricks But I did do a kitchen like this yesterday I used tons of water and ran snake in and out for a long time . I will say people (women) wont listen they dump pots full of everything down kitchen and grease too , they always deny too.
Bucknut
Reach4,
Thanks again for the reply. To be able to run water while I snake the drain, what if I remove the vertical and horizontal pipes from the non-disposal sink then slowly run water down the disposal side?
Bucknut
JHY,
Thanks for responding. Was this a soap-grease clog? Did you use a 1/4" snake? Was the general purpose head used or an arrow head or u-shaped grease tool?
And how many times would you estimate you ran the snake in and out?
My wife was extremely careful with what she put down the drain the last 10 weeks since the drain was supposedly "cleared."
JHY,
Hi Bucknut, I used a 3/8 inch cable the tip was flat metal in shape of an arrow head rounded corners there is another tip thats like a spear tip. I ran my snake back and forth about a 5 foot section about around 10 times. In this case the clean out was on an outside wall a mess of spaghetti all over ground. The guy I cleared it for said he had someone clear it a month or so ago its all plastic 35 years old under a slab around a 25 or 30 foot run of 2 inch till it joins a 3 inch main
Im kidding a bit about everyone lying about what they put down drains I try to be careful
Bucknut
JHY,
Thanks for the pro tips!
Unfortunately, the only tip-end I have is the standard coiled design.
I'm not sure of the best way to use it to remove soap grease that's probably on the walls of the pipe.
Any suggestions / advice would be greatly appreciated.
Bucknut
Reach4,
Reach4 and others,
A reply would be greatly appreciated. Thanks!
royalflush001
Texas
Try pouring hot water followed by baking soda and vinegar. wait for some time and wash off the solution. Also, you check your garbage disposal once. I hope this will work. A good drain cleaner will also work wonders.
