Is this a "wet vent"? Would this be okay for most local codes?
santhony7
Golden, CO
I am completely re-doing my plumbing. The blue lines are my waste and the black dots are vents that go through the roof (well, they will combine in the attic). Large blue circle is the "stack". Is the venting setup for the toilets set up okay? 4.Toilet uses 5.Lav vent and 7.Toilet uses 6.Shower vent? Thanks for any help y'all.
santhony7
Golden, CO
This is on the first floor. All vents exit the roof. This is a top down view in case there is confusion.
Also, I see the error. It was just a misplaced line. I didn't mean for the waste to loop.
James Henry
Billings, Montana.
If its in a crawl space or slab then you can use 45 degree fittings every where.
Aim all your fixtures towards the stack and run your vents up the walls you pass on the way. You have all your fixtures drains heading away from the stack. Your plan Will not work.
santhony7
Golden, CO
It's a basement and I'd rather keep the sewage lines running parallel to the joists to maximize headroom even though this area will be for storage only. The only fixtures draining away from the stack are 2.bath and 3.bath because I'd rather the drain pipe be at the end of the storage room. Why would it matter as long as it is sloping? How would this "not work"?
santhony7
Golden, CO
Okay. I see where you are going. Yeah the 3.BATH vent distance is on the 6' mark and it will be a 2" vent. All the vents will be 2" likey.
Do you think the 6.shower and 7.toilet could share a vent? Not a big deal to add them both but thought I'd ask.
I also can move that 3.bath since it doesn't even exist yet.
So the 4.toilet can be wet vented with 5.lav?
santhony7
Golden, CO
Also, thank you for your time and patience. I know it sucks helping newbies sometimes. I am going to hire a plumber as a consult before I begin work. I just needed something to give to the county for a permit.
James Henry
Billings, Montana.
Contractors like to wet vent everything to save money but when its your home the more vents you have the better.
santhony7
Golden, CO
Yeah, I understand. I guess I’m just try to reduce the number of walls I need to open upstairs since they are all finished. Guessing I don’t have much choice. Thanks again man. Much appreciated.
James Henry
Billings, Montana.
In case your unaware. The vents that are side by side in the walls can be tied together at 42" above the finish floor and then you only have to
run one vent through the top plate. Also, the city of Golden CO. uses the 2015 edition of the INTERNATIONAL PLUMBING CODE.
You can read it online. It'll save ya. Later.
