Is my water treatment plumbing backwards?
diyMCO
New York
After living with odd water quality issues for a few years, I just noticed that my 2 year old filter and softener are potentially plumbed backwards. I believe I have Fleck 5600 controller on top of both black tanks. If I believe the arrows on the bypass valves, the feed from the holding tank is connected to the "outflow" of the bypass valve on the carbon filter; carbon "in" is connected to softener "out", and softener "in" is connected to the house. See picture with carbon filter on the right, softener on the left.
In your photo, inputs are on the left, and outputs on the right. If that was hooked up by a water treatment person, they should correct it free. If you told the plumber how to hook it up, then you pay. However, a softener works better hooked up backwards than you would think.
The PVC should be painted to protect from UV, and the controllers should have a cover to protect from UV.
ditttohead
Water systems designer, R&D
Ontario California
Typical installation is GAC first then Softener. Arrows on the bypass indicate flow direction. Plumbed in backwards will work but you run the risk of a failed top screen which could fill the house with media. Most top screens are designed for shipping and diffusion, not to hold back media. No meter on the softener? Those are rare, not really advised. When you upgrade in the future change the valve to a metered type.
Bannerman
Ontario, Canada
As your location is indicated as New York, with NY winter temperatures, how are these located outside?
