Hi
My well pumps have been only lasting 2.5-4 years.
Well is from about 1990
Moved here in 2013. Pump was from 2011-2012. I didn't shock well at all before first one failed . November 2015 I was getting no water and it turned out the pump was caked in iron and the pipe was full of it. Replaced pump and pipe
I Shocked the well in every year after that. However in May 2018 I was getting reduced flow and pump couldn't deliver enough pressure it seemed.
Called well guy and similar thing....however this time much less iron around pump and the pipe was not bad at all. Replaced pump and back to normal. Well guy just said there is not much to do.
I kept this pump...the motor seems fine...the impeller head does not turn that smooth. I was told by Franklin (pump manuf.) some people have had luck putting clr in the pump end overnight and then flushing iron out....I noticed that I could put it in on the output of the pump and it went through slowly. I have not tested it to see if its working again...I would need to rig something up.
Pump is Schaefer 3200 1/2 230V 3 wire
Pics of original pump that died with caked iron....newer one that failed did not look nearly as bad
Anyway...anyone have any suggestions? I don't mind taking pump out every year to clean pump head if needed but I'm not sure what is best.
Shocking the well didn't seem to solve the problem.
I was told by one guy that might make it worse with the well casing
I've asked a well digging company and they suggested redevelopment of the well or high pressure...ive also read about some companies that clean wells with an "air shock" device...
Any help would be appreciated.
Thanks
Thanks
