In need of advice basement plumbing rough in DWV
You can't put a no hub coupling on a fitting it has to be on a pipe.
Even if that is a street fitting? I would make sure that the coupling is tightened to 5 ft-lb (60 inch-pounds).
Lubing lightly with dish soap can help the rubber flow to fill tiny imperfections.
Jeremy7835
Minnesota
Replaced it and tightened to 5’ lbs and it leaked
Gave another light tightening and it stoped Inspector passed it and said best he’s Seen a home owner do I am clear to burry it and went out and grabbed 16 bags of concrete tonight but didn’t have time to get at it
James Henry
Billings, Montana.
For future reference. A pvc street fitting is not designed to accept a no hub band. Some people do it but I don't trust it.
Jeremy7835
Minnesota
Yes James water lines will be easy I removed the rats nest of copper that was here before and installed pex
I have a pro press cause I’m a boiler guy so that stuff is a bit mor up my alley
Jeremy7835
Minnesota
Jeremy7835
Minnesota
James how should this be redone
The double wye looks like it would suck the traps dry
I plan to put in a 3” santee up in joist space and connect toilet with 4x3 closet bend
Then put a double santee about 8” below and connect sink and tub to that
Does that sound ok?
Jeremy7835
Minnesota
Does that sound ok?
Jeremy7835
Minnesota
https://www.pvcfittingsonline.com/3...MI_OSYibP75gIVEY3ICh36WwhQEAQYBCABEgJM8_D_BwE
This is the correct way. Mount your toilet flange to the floor so it sits on top of the floor tile and run the rest of your plumbing from that point.
Aww man I didn’t even think of side inlet santee lol I was trying to figure out how I was gonna do the tub without having to bust wall open and put a santee off trap and put trap into that cause it appeared I’d make an s trap if I kept the tub trap up inside joist space!! You are awesome!!
James Henry
Billings, Montana.
10-4. Enjoy.
Jeremy7835
Minnesota
10-4. Enjoy.
I got a bathtub that has a 3” chunk of styrofoam on the bottom??? my floor is unlevel I’ve poured 100 lbs of leveler to true it up but I didn’t pour where the tub goes because I planed to dump mortar in there and then set the tub.. can I use mortar under this tub or will it melt the foam? Directions say I can... anyone have experience with this?
James Henry
Billings, Montana.
I would follow the installation instructions for warranty purposes and I would also read the numerous threads on this forum about best practices for setting a tub.
Jeremy7835
Minnesota
Yeah I found a ton of threads but nothing talking about styrofoam on the bottom
Jeremy7835
Minnesota
Think I got it... not to bad at all..
