In need of advice basement plumbing rough in DWV
Jeremy7835
Minnesota
He I’m new here this is my first post. I just need a little help with direction on my dwv design here
Can any one tell me if this is ok to do sorry I’m no artist but I drew a rough picture
Jeremy7835
Minnesota
These pictures may help sorry for the mess
James Henry
Billings, Montana.
This is the safest way to pass inspection. Keep all drains tied in horizontally.
Can I also tie the floor drain and laundry sink in here some where? It is 2”
The laundry sink gets it's own drain and vent. It can't be part of a bathroom horizontal wet vent.
James showed you how to wet vent the bathroom. The laundry needs to come in downstream of that.
Jeremy7835
Minnesota
Can I tie in like this from laundry to bathtub drain
Jeremy7835
Minnesota
Like this or all the way back to the 4” cast iron?
Jeremy7835
Minnesota
Are you just trying to tie the existing floor drain into the new drain or are you moving the laundry sink too.
yes James I need to tie the existing floor drain and sink back in currently it’s tied in with the old shower and then dumps in after old toilet
Jeremy7835
Minnesota
How about this guys then I have cleanout under lav and I’ll just run a 3” vent to attic and tie all vents to that above sink
The laundry tray can't be part of the bathroom plumbing.
The laundry tray comes in lower than the bathroom after it's vent vented. The lav can wet vent the toilet, the laundry tray can't.
Jeremy7835
Minnesota
I don’t understand how it is Terry the laundry dumps in after everything.
Are you saying I can’t tie the vents together here?
Jeremy7835
Minnesota
The sink isn’t moving
I could turn it and put up against the stud wall if easier but had no plans to move it
James Henry
Billings, Montana.
Then I'm guessing you're going to attach it to the new plumbing like in your drawing. If that's the case then move the floor drain pipe so it is to the right of the tub p-trap and not overlapping the other drain and your drawing with work.
James Henry
Billings, Montana.
You maybe be able to run the shower drain off the floor drain pipe and roll a vent off that into the wall.I can't do a working drawing off of chicken scratch and my cell phone. No offence.
Jeremy7835
Minnesota
The pipe currently runs where I’ve marked blue
