I messed up!!! Loose Shower valve
Ddiss11
Newark, OH
I recently completely gutted and renovated my full bath and made a huge mistake and wanted to see if anyone had any ideas before I start tearing things back apart. Durring the rough in I placed a horizontal 2x6 between the studs and mounted my valve to the 2x6. Well apparently the 2x6 was such a great fit that I somehow forgot to screw it to the studs…I have a fiberglass surround and the bathroom is now completely finished. Earlier today I went to install the trim on the valve when I realized the mounting block is not secured to the studs. Does anyone have any other methods of securing the valve. I was thinking I could possibly get an angle drill and a long extension to possibly get some screws in it but it’s going to be a tight fit, anything is worth a shot before cutting back drywall and removing that section of the surround.
Also the shower backs my kitchen wall so cutting a access hole from the other room will not work.
Thanks you
Blocks of wood and the trim screws should hold it tight. Wedge them in between the pipes and the tile backer. You might have to chip away alittle to get the blocks in just stay away from outer edge of trim so everything covers
Sometimes valves are plumbed to fiberglass showers using the plate that comes with the faucet behind, and then clamped tight with the trim.
Jeff mentions wood blocking between the valve and the surface. Something like that can work. There are times when we have run across valves without the support, and we find a way to secure as best we can by wedging things.
Tuttles Revenge
How far away are the studs from the center of the shower hole? Is there any way to insert a very long screw bit tip and get a screw or 2 into the corner of the horizontal? or just into the stud enough that it keeps the horizontal from moving forward?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Perhaps you could spray just enough expanding foam at the ends of the horizontal brace to fill the gap without getting it onto the valve body and piping.
LLigetfa
NW Ontario, Canada
John Gayewski
Iowa
Use construction adhesive and glue the corners to the studs. Or you could glue a chunk of wood on two sides and place it on the corner as a bracket. Wood glue or construction adhesive is extremely strong on wood connections.
