I’m in a private house, on a water well with a jet pump and bladder tank. The pressure gage on the jet pump shows me that the pump turns on at 40psi, and off at 60psi (with a little plus or minus each time). The bladder tank is less than 2years old. The main supply line from the bladder tank is 3/4" copper, and branches to 1/2” copper for each fixture. All copper piping is <10years old. Although I have hard and slightly acidic water, none of the 50year old copper pipes that I removed (in the past 10years) had any appreciable buildup within them. I have purchased but yet to install a water softener/acid neutralizer. The valves and valve assembly to the tub/shower were replaced this year, as was the tub's spigot with diverter to the shower head. The diverter/spigot works very well: leaks only a few drops when the shower is engaged.
All that being said, my shower isn’t as strong as we would like it to be and comparing to other showers (i.e. in hotels, on vacation, stays with relatives and friends, etc) makes us think there’s something wrong with our system. I realize that's a very subjective observation, so is there any *quantifiable* way to check our shower’s flow/pressure etc. and compare to (for example) a relative’s or friend’s house?
Putting a pressure gage on the shower head will only show me the static pressure, so that’s kind of useless. I’ve installed new/different shower heads but the result has been the same somewhat lackluster shower. I suppose it’s possible that I did a sloppy job at soldering a joint somewhere and there could be a partial restriction in the line, but how could I test for that? I’m only familiar with larger flow/residual pressure tests done on fire hydrants. Is there any objective test I can run on my shower and compare (apples-to-apples) to someone else or to a written standard? Just looking for some quantifiable way to check so that I can prove to the missus that, short of jacking up the 60psi setting on the pump cut off and increasing the risk of a leak in the walls somewhere, our plumbing is operating as it is supposed to.
Many thanks
Theodore.
Many thanks
Theodore.
