JWBlue
Plumber came to drain the hot water heater.
Now we barely get hot water.
Is this electric or gas?
Look at the dial for the temperature setting. He may have turned it down low during the flushing and then didn't rotate it back up again.
On this one "HOT" is 120 degrees, or close to that.
I could swear it was on the "Low" setting before the plumber came but not sure that makes sense. Plumber said he didn't touch the dial which I do not know if is true or not. It was on "Low" when he left.
Turned it up to "A" this morning. Had no hot water for a morning and afternoon shower. Just turned it up to "B". According to manual A is
125°.
What is standard procedure for draining a hot water heater? Manual for hot what heater says to turn off power.
I asked the plumber this and he says it is not necessary.
Your gas water heater has " POWER" electricity going to it? It has no pilot? get a bit of basic info please if its a regular gas water heater it wont have power going to it. but a normal gas heater has a pilot maybe pilot is out .
I missed something? How did you guys figure out which water heater and controls he has? It seems Terry posted a picture of a water heater but no indication that its anything but a random gas water heater , causing me to be at a loss. Unless its an old gas water heater the status light should blink if its lit. But I think the homeowner has already called a plumber to fix it and dosent need help just too busy to let us know
We should try guessing what you do own.We do not own the Honeywell. Good point.
Would your hot water system by chance happen to incorporate a recirculation pump?We are getting hot water but it is slower to become hot.
If a recirculation pump is shut-off, hot water could be slower than usual to arrive at faucets even when the water quantity and temperature within the WH is more than sufficient.
