Efrain
Hello all,
I'm new on here but this place has been very helpful.
To give as much background as possible .....this will be a little long.
I have an about 400ft well pump (no clue on model, just moved) with originally a 20gal wells troll pressure tank. Running on a 40/60 psi setup.
About a month ago as I was attempting to top off my swimming pool I noticed my pressure dropped significantly and pump was not shutting off. Jumped on this forum and saw some tips and tricks here and there. I shut the breaker and drained tank checked air pressure..... it was like 10psi. Imidietly knew it was the tank.......
Replaced the tank with an A.O. Smith from Lowes (with new switch, huge and fittings) but I couldn't get the system up to the 60 psi so pump could shut off. So in order to have water a d assure pump wouldn't constantly run I dropped the pressure to a 25/45 psi setup. That seemed to be working ok. A week later (after I got fed up with the fact I couldn't spray off the soap on my car) I decided to try and set the system back to a 40/60 setup.....and wouldn't you know it everything worked out ok. ..........fast forward to today a month later ,,,,,,,,
I was watering my lawn (same faucet used when topping off pool) and pressure dropped again.
Background on faucet location: first T off right after the tank.
I turned off the faucet and now pressure again does not get a ove 35psi, and while water is going in the tank, it's not much because I can shake it easier than before.
Tank is holding pressure at the 38psi setpoint
Pressure when faucet is open/ no water in tank .... is about 15 or 20 psi.
I have a couple of thought and need your help.... I'm thinking weak pump or something a obout me running this faucet is causing issues.......
I was thinking maybe my pump "overheated" and isnt strong enough to pump up the pressure , so I turned the breaker off for the night and will check again In the am.
Any help would be appreciated
