Help with Symmons tub/shower faucet
Diane1166
Massachusetts
Hi! I'm trying to fix a leaky tub spout but I'm having a problem removing the spindle. I'm learning as I go and have watched many videos on Symmons faucet repair. I don't know the name of the 'nut' that you need to remove because everyone calls it something different, but, it was on really tight so I needed to use a pipe wrench to get it off. So far so good. Now, supposedly, you're supposed to be able to pull the spindle out but it will not come out. It doesn't feel like its stuck, it feels like there is a hard stop when I try to pull it out. By this time it was late so I put it back together to turn the water back on (there isn't a way to turn off the water to the tub so I have to shut the main water valve to the house). Now, the spindle is so tight, it doesn't turn easily at all now. I didn't something wrong, I don't know what. I attached a picture of the spindle with the 'nut' taken off and this is where I am stuck. Any suggestions at all I would be grateful for.
