Symmons shower/tub valve - low volume and little hot water
Phantomracer
Boston, MA
Having an issue with the Symmons shower/tub valve (shocking I know) . The volume of water/pressure is low, and the temp does not get very hot.
The diverter (ta-25a) was stuck, so I removed it. it is working now (unrelated but I wanted it fixed)
Removing the shower head, the volume of water does not seem that great, so it is not the shower head. The volume from the tub seems about the same. Temp gets barely warm enough,
the only other part that seems that can be easily replaced is the TA-10 spindle and the hot/cold seats. I have not removed the spindle yet. Could this be a potential source of the problem?
Thanks for any help!
for reference - valve parts
Definitely it's the cartridge. It could be clogged up with hard water deposits prevent the thermostatic control from correctly working.
If any part has neoprene washers and O-rings, replace them. At the symmons web site has a real nice parts break down if it is your model. The rebuilt kits are in three sections that included everything including the seats. The seats do have o-rings. Danco does have a few parts with o rings only, https://www.danco.com/?s=symmons&post_type=product. I would only go with symmons parts.
