Grohflex max and min limits
Jechow
British Columbia
Hello. I've purchased a Grohflex rough-in for my new shower. On the rough-in there are max and minimum limits. On the sticker there are arrows. Is the manufacturer indicating that the finished tiled wall shouldn't go past the arrow labelled maximum? I am asking because the tolerances seem a little tight since the max. arrow is 4" from the backside of the unit. Here is my rough calculation. If the rough-in is installed into a 2x4 wall the stud itself is 3.5" then you add in the 1/2" drywall plus 3/8 for tile. This means you can only have 1/8" of thinset to be within tolerance. Thanks.
If you want the trim to fit...yes.
On another point, unless you are using either Kerdi or Hydroban sheet membrane, drywall has no place in a shower!
Jechow
British Columbia
Thanks Jim. I was just concerned how accurate can Grohe be with just a sticker indicating max and mins. I guess this means that I should install the rough-in only partly recessed into the wall instead of against a board attached to the backside of the 2x4.
Yes, I will be using Kerdi so surprisingly drywall is the recommended backerboard.
Cheers.
DougB
Minneapolis - Land of 10,000 taxes
Install the rough-in so it will at least slightly protrude past the cement board and the tile. After the tile is set, you then trim off the excess ( I used a shop knife ) - flush with the tile..
Brianthedog
michigan
How did your project turn out ? I ran into the same dilemma stressing over how the final valve assembly would fit or not.
