There will likely be less than 120 gallons remaining when regeneration actually occurs.My system should regenerate once it gets to 120?
It will regen at 2AM (if RT is set there) the night after you count down to zero. The reserve was already deducted from the number when the countdown started.My system should regenerate once it gets to 120?
Hi @Reach4 So, I tested my water again last night. The amount to Regen on the display read 51. It still takes 2 drops for water to turn blue.
Thoughts?
I would trigger an immediate regen. Then test as you have 300, 200, 100 gallons left until one drop no longer turns the solution blue. Then based on that, do a calculation.It was a cold water test.
What would you recommend for setting to tweak a bit?
Just H setting? or should there be other one?
Granularity would be the ability to cause the initial gallons to be 89.9% or 91.5 percent as much as now, vs 88% or 92%. Not a big deal.Would more granularity effect much? Trying to find that balance.
I really appreciate you taking the time to explain everything. I'm learning alot.
Yes, you clarified that in post #34.It’s 2 after being softened.
