Fleck 5600sxt questions
Discussion in 'Water Softener Forum, Questions and Answers' started by J0501, Jul 14, 2020.
  1. J0501
    J0501 New Member
    Jul 14, 2020
    Tucson
    How do I advance it straight to brine draw?
    Where would I sample the water from? The drain in my laundry room?
  2. Bannerman
    Bannerman Well-Known Member
    Mar 19, 2014
    Ontario, Canada
    From page 6 of the 5600SXT Down flow Service Manual: '
    The Parameter Display displays the current Cycle Step (BW, BF, RR, etc) during regeneration, and the data
    display counts down the time remaining for that cycle step. While the valve is transferring to a new cycle step,
    the display will flash. The parameter display will identify the destination cycle step (BW, BF, RR, etc) and the
    data display will read “----”. Once the valve reaches the cycle step, the display will stop flashing and the data
    display will change to the time remaining. During regeneration, the user can force the control to advance to
    the next cycle step immediately by pressing the extra cycle button.'
    Obtain your testing sample as close to the softener as practical. If there is a coupling which joins a short section of drain tubing to a longer section running to your laundry room, separate the sections otherwise, remove the drain tube from the softener to temporarily install a short section. The shorter distance from the softener will help you to better judge when the drain flow becomes salty.
  3. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    A TDS meter would be a better/easier alternative than tasting, especially since the suspected leakage is not as great as it is in some cases. Not necessary, but when the salt hits, expect the TDS to rise to over 1000.
    TDS does not measure hardness, but is is really good at picking up this salt rise. They are cheap. No need to get a high grade one.
  4. J0501
    J0501 New Member
    Jul 14, 2020
    Tucson
    Can you explain why you think the seal may be the issue instead of a settings issue? Thanks.
  5. Reach4
    Sep 25, 2013
    He can, but can you explain how it could be a setting issue? Nope.
  6. J0501
    J0501 New Member
    Jul 14, 2020
    Tucson
    Ok, so I did the check as you described and it did not taste salty....thoughts?
Similar Threads: Fleck 5600sxt
Water Softener Forum, Questions and Answers Fleck 5600SXT hard water Jul 29, 2020
Water Softener Forum, Questions and Answers Fleck 5600SXT: Inverted water flow discovered during installation Jun 26, 2020
Water Softener Forum, Questions and Answers Fleck 5600SXT settings in Hot Climate? Jun 24, 2020
Water Softener Forum, Questions and Answers Fleck 5600SXT Pre Pre Install Questions Jun 21, 2020
Water Softener Forum, Questions and Answers Fleck 56SXT vs 5600SXT Apr 28, 2020
