Alex S
Hi there,
I have a new toilet install happening where the 3" closet elbow under the toilet is 14ft away from the 4" main drain that I will be WYE fitting into at a 45. (4x4x3 here).
If the closet elbow sits just under neath the toilet flange (+ room for connection) The elevation difference is 17.5" from the main drain to the elbow under the toilet.
Fall isn't an issue per say, 1/4" per foot means I need 3.5" of fall. No issue on not enough fall, but rather the opposite
My question is how would this typically be done? Would you drop the closet elbow under the toilet a bit to allow the connection to make up?
I am fearful that I will approach the WYE at too aggressive of an angle to make up the connection.
I'm sure there is a "maximum approach angle" or something to that effect that dictates you must come in at a fitting without too much slope or the connection would never be possible.
See the image for what I am asking, but I think my question is pretty straight forward:
How do you deal with making up the connection when allowing fall? Is there a measurement you make to ensure the connection will mate up? Or is this eyeballing and experience?
Thanks guys so far you have been hugely helpful.
