Drain Vent placement
Dasadler
California
Hello all, new member here. I live in Southern California.
We are going to have a bathroom moved from one interior part of the house to another part which will be against an outside wall.
It was suggested that sink, shower, and toilet drains can be vented out the wall instead of through the roof.
Does that sound right? If not, why not? (so I can make a convincing case)
Thanks you,
Don
Sylvan
Still learning
New York
Only vent I know of through a wall is the fresh air inlet and the vent terminal is through the roof
Asktom
Victor, MT
Through the roof, that is the code. Actually, it could be run through the wall (at a 45 angle or 42" above the floor if a 90 is used), but you would need to then turn it up and run above the edge of the roof.
MACPLUMB
HOUSTON, TEXAS
Unless you live in the Boonies it is against code people do not want to look at those nesty old pipes,
I haven't seen any in So. CA. since back in the old days of the 70's on really old houses that were never built with in door plumbing,
this is a building code Issue
