Double Y joint?
BeerMonger
Hello everyone. I am in the process of installing a dishwasher in a home that did not have a DW. I am trying to hook up the discharge runoff hose on a double sink, single trap setup. I have the tailpiece but there does not seem to be enough room to fit above the trap because of the T piece that connects a pipe to the second sink.
Can I just use a Double Y joint above the trap and install the dw tailpiece on one side and cap the top?
This way I would have the dw discharge going down one side and each sink basin using it's own outlet on the double Y joint. Just not sure about capping the top of the one side for the dw dishcharge.
Thanks for the help!
Sjsmithjr
Knoxville, Tennessee
You can install the dishwasher tailpiece horizontally, vertically, or built in to the end outlet. More detailed responses to follow; I'm sure.
Dw
If you have room enough below the tee for the "Y", then you also have room enough for a "slip joint" tailpiece which takes the place of a section of tubing. if you have sch. 40 trap and piping, which you would need to install that "Y", then just move the trap adapter down near the trap and replace the riser with the branch tailpiece.
Sjsmithjr
Yeah, I definately needed visual aids with that reply. If the height of the trap arm does not allow for the use of slip fit dishwasher tailpiece in the vertical position immediately above the trap arm:
Then it might be possible to install it horizontally:
Or go with a dishwasher inlet made into the branch outlet, as that will raise the dishwaher inlet above what one could get using a slip fit tailpiece.
...and yes, a pic of the OPs setup would be most helpful.
BeerMonger
Thanks Guys. It looks like installing it horizontally may just be my best bet. Sorry the pic is so bad.
BeerMonger
That or a high loop above the top of the DW. I think I will just go with a high loop. :D
