Esachs4
So, I ordered too much cable length for my ditra heat. To make it work, I alternated 3-2-3-2 studs as Schluter says you can. I made sure I stayed 7in away from toilet drain centerline, but i still had to run cable under where my vanity will be. I kept 3 and 4 spacing under the vanity to keep heat from building up. I know Schluter says not to put the cable under the vanity, but the bottom of my vanity is open. Will this be okay or should I order new cable? Do you see anything else wrong with my layout? Thanks in advance.
