After research here and over the web in general, its a no brainer that I want a Delta Pull Down Diverter.
The picture below is how I rigged it to install my current leaking generic diverter to be the right depth from the wall.
As you can see, I can start at the 1/2" NPT steel and add whatever is necessary.
I understand the general difference between the 17453 (sweat or thread connection) and the 5836 (slip on with set screw.) However, without holding each in my hand, I have no feel for dimensions, pipe needed, etc.
I'm quite sure I could go either way - So is one better and or easier than the other?.
If choosing, I'd rather have better than easier.
Thanks in advance, Rob
