Delta Freestanding Tub Filler Installation
Richard Schrodeer
We recently remodeled our bathroom and decided to install a Delta Freestanding tub filler, wanting to make sure it was installed correctly we hired a plumber. At the time the floor had been ripped out, since then we installed cement backer board and tile. When we went to finish the installation of the tub filler we realized that the plumber did not insert the screws that attach the filler in the mounting bracket. Is it possible to attach the screws from the top down or will that compromise the stability of the filler too much. We had also considered opening the ceiling from below and trying to install them that way. What would the best solution be for this issue?
it should be apparant what needs done, not rocket science . without really diving into research it sounds like you failed to install something befor tile so correct way might require removing tile. cant / wont your plumber walk you through and explain it? dont know how the job is being run but if I screw up I am responceable . If I dont screw up it isnt my problem. someone needs to be able to unravel this, or maybe the screwes arent needed and no big deal.
Tuttles Revenge
There are 4 mounting bolts needed to hold the faucet to the rough in valve. Those should have been installed at rough in if they weren't already installed at factory. If they arent in place they can be done from the top.
If the rough in body wasn't screwed to the floor you may need to work from both sides to fix it depending on what you need to do. If the wood backing/blocking/support is already in place you will need to add screws from atop to secure it. You will also want to make sure its level and shim as needed. If you need to add the support then likely you will need to do that from below.
