hygron
I cut the power, and replaced pressure switch. Pump still ran, and I assumed pipe to outlet of pump had broken allowing pump to run. After pulling pump up, and replacing coupling to pvc which broke off completely right as I was pulling the pump out of drop pipe; I replaced pump into well, and cut on power. pump is still running, but have absolutely no pressure.
Is this possibly a sign that the impeller has broken,,and although pump is running, no water is pumping up the line?
Thanks ahead for your help. Great forum, hygron
