Cycle Stop Valves: Can They Shorten The Life Of Your Well Pump?
Drdialtone
Texas
Three months ago, I installed a Cycle Stop Valve (CSV) and removed the large pressure tank after doing the same for a neighbor over a year ago. He just called me to say that his pump went out and the technician who serviced his well told me it was due to the CSV causing the bearings to go out on the pump. After speaking at length with the technician, he told me he has had to replace several pumps which use a CSV and in every case, it was the bearings went out on the pump. Now I am wondering if I should replace the CSV with a conventional tank as it was for many years.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
OMG! Find a different pump man that knows what he is talking about. Bearings in pumps do not go out from the low flow conditions of a CSV. The new style Franklin impellers are crap, and will not take low flow from a CSV, Dole Valve, or even a ball valve, but it has nothing to do with bearings. The thrust bearing in the motor can be destroyed with less than 1 GPM, but the CSV has a 1 GPM minimum, so that is not a problem.
Usually the pump installer just doesn't know what he is doing and picks a pump that cannot build enough pressure to shut off the pressure switch. That will melt impellers in a pump, but not the bearings. The CSV is just a good scapegoat for an installer who gets something wrong or just uses cheap pumps. If he can't figure out what he is doing wrong, it is easy to blame it on the CSV. I wonder if he even knows the difference between pump bearings and the impellers? It doesn't sound like it.
Tell your neighbor to send me the old pump and I will tell him what really caused it to fail.
Now there are some pumps out there that are having bearing problems. I believe Craigpump said they are Pentair pumps.
Drdialtone
Texas
Thanks for the advice. He has had to replace his pump three times in the past ten years, which seems like a lot. My pump has been in since 1989, (I bought the place in 2005 and have all receipts from the previous owner) which tells me it's a very good pump. I just don't want to have to go through the expense and headache of replacing it.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If he has only had a CSV for a year, and has had to replace the pump 3 times in the last 10 years, the CSV is not the problem. But somebody needs to figure out what the real problem is. The pump man likes replacing the pump every 3 years or so, so he is probably not going to be of much help. And if that pump was in the well a year or two before the CSV was installed, the CSV can't do anything about the damage that was already done to the pump. Normally pumps that only last 2-3 years are being cycled to death, but there could be other reasons. If I had one of the old pumps to look at, I could tell you what is causing the failures.
PumpMd
Kevin
Oklahoma
Warranty pumps every 3yrs or so? The pump guy doesn't want to warranty pumps,mad customers, and bad word of mouth to spread around for his business. Send your pump/motor to Valveman so he can see the cause of the problem.
Craigpump
The problem I've had with Pentair is with the 1hp-5's. The shaft deflects then wobbles like a drunk old lady in high heels..
