Shakaworld
I looking into getting the Custom PK1A PSIDE-KICK Kit - 10 gallon
Valve setting: 70
I currently have a 62 gallon tank on a well with a 1hp pump with 1 inch piping - right now the pressure switch is reading 55 psi would getting the csv with a setting of 70 psi help with the pressure drop when going through the carbon filter and water softener or would a scala2 pressure pump right before it enters the house be a better solution for higher pressure (all equipment is outside) - if I put the softener an carbon filter in bypass I can see a noticeable difference in pressure and flow with the faucet in the pipe right before it goes into the house
Valve setting: 70
