Yar02169
Hi guys with all the answers!
You have helped me in the past, and I'm going to pick your brains once again. Long story on my well is that I have an issue with silt. I've given up on trying to develop and be rid of it, and now I just deal with it. [irrigation only].
I have a 10"x4" whole house filter mounted after the pump, before any zone valves. I now had to clean the filter for the second time this season. The silt is usually only an issue on pump start, if any comes up while watering, it's minimal
Now, I've omitted the pressure switch and went to a timer system. That has eliminated any zone valve leak dropping pressure and turning on the pump. That caused issues because the pump didn't always build enough pressure to shut off, and would/could run for an extended period.
When the system shuts down, I can hear back-flow. The prime drops, as well as whatever pressure was in the system to the zone valves. My guess is there's not enough head pressure for the check valve to close properly, and is all flows back down, mixing up a silt storm for next time.
I think I have a couple options, or a combination of options, and here's where you pros get to shine.
Option 1 - Replace the check valve with a solenoid valve (normally closed). When the switch turns on, the valve opens and we're off to the races
Option 2 - Install a "start zone". Remove the spigot and install a zone that would run the first 5 minutes or so. It would allow the pump to purge out the silt, and then switch to the filter and feed the system.
Option 3 - Both, or a better idea that you may have.
A picture is attached, because why not. I thank you for any help you can provide.
Ray
Ray
