Scott Olsson
Obviously there are details to figure out, but am I on the right track? Thanks!
Say the washer comes in right below the red vent.
Here I think I've fixed the washer drain. Does the 1.5" vent on the small lav count as a wet vent for the shower? Or do I still need to vent the shower?
Would I have a better chance of getting some help if I simplified my question a bit? I realize this is asking for a lot of help and there is probably a lot wrong with this...
If you do this it's a lot easier for people to help you.
1. Orient your floor plan so it's going the same direction as your plumbing plan. Include ALL the fixtures and LABEL them properly.
2. Draw a dotted line on your floor plan where the existing drain line is that you intend to tie into, also size.
3. Is this on the first floor?
4. What material is the floor made out of? crawl space ?, concrete ?
5. Can a vent go through the roof anywhere on your floor plan?
Are you planning on running the drains under the floor joist's or inside them? If your planning on running them under then it's a walk in the park.
I'm an over builder too. Does 3" make it drain appreciably better or just decrease the chance of a clog?I would think about running the washer drain in 3" but I'm a natural over builder.
