our master bath reno is well on its way… all demo's have been done (and more as usual)… we are changing a 5'x8' bath room into a 8'x17' master bath. the photo shows the vanity wall in its stripped down mode… the notes show where we have planned on putting the new features, using as much of the existing plumbing as possible. I have a question with respect to the existing plumbing and how it fits with our new plans.
Left side of photo: My intent was to cut into floor immediately in front of the the old tub drain pipe and replace with a vertical section of ABS, run it up to form a new config including a P-Trap for the sink on that side. However the floor joists below preclude me from doing that. So, I can't find where there are minimum/maximum drops from the sink to a P-Trap and need your advise. As you can see we are building out (2x4 wall) two 32" sections of wall (left and right sides) to accommodate the wall mount Faucets. If I run a 90º elbow from the old tub drain (shown, lower left) then a vertical section up to the stone sink will this function? Pros and Cons? I imagine I will have to make it come out of the wall at some point so any suggestions for best practice would be appreciated as well. What type of joint would be best? a couple of 45º elbows?
The Existing left side P-Trap is 21" from the vertical run to the Vent stack. That vent stack will be about 7" - 8" from the bottom of the stone sink. At the far right of the photo is the 3" Waste Stack.
