Unlikely...sorry. Concrete is not waterproof, but is not damaged by becoming wet. That floor may or may not be sloped, but that's the least of the issues. Moisture wicking into the walls can create lots of damage.
Thank you for your reply!
My need is for an, "ADA" type accessible shower downstairs for an elderly relative moving in who can't use the stairs.
The laundry room is a pass-through from the house to the garage. The family will be walking through the "shower room" to access the garage.
It's the only place/solution I can think of to add a shower. I was hoping that the drain would be adequate—in plumbing standards—to use as a shower drain. The floor is slightly sloped towards the drain.
Like I mentioned, I have a very limited budget, so I'd like to avoid any jackhammering to add another drain. I'm hoping to have a contractor friend install a hand-held type shower. (That's about all I afford him to do)
I plan on waterproofing the walls (somehow—researching that) and adding a curtain. I'm also researching how to block water from going under the doors, if needed.—I've seen rubber barriers you can adhere to the floor.
Again, my main concern is that the drain will work fast enough as a shower drain. I guess I can experiment with a hose and see if it will work.
Thanks again for your reply. If you think of anything else that might help, please chime in.
