Curtis T
I was changing the tub drain when it snapped, after opening the wall, I tried to remove the brass fittings to change out the drain portion. The threaded brass tailpiece snapped off during the process (old corroded fittings). The tailpipe goes into a black plastic pipe with a nut on it. I removed the nut, but the brass pipe won't budge as I try to remove it. The brass pipe begins to compress if I use a pipe wrench, so that doesn't work. Oh yeah, very confined space to reach into to access it, so I cannot simply remove the trap and pull out the unit to work on it.
Any ideas?
The photo is with the phone stuck inside, I can only see what's on the top right of the pipe
Any ideas?
