Briggs Tank Replacement
ShawnN
Arizona
Heya all,
I rolled through a few threads regarding tank replacement but didn't see one addressing this question.
I have a Briggs model 4930 tank that cracked up the side. I understand that the model is obsolete but I found a website called cheap toilet tank lids dot com. They appear to specialize in old tanks and lids.
Was wondering if anyone had experience with them? Legit or not? I'd really rather just replace the tank rather than the toilet as the rocket scientists that lived here before me installed the toilet on the concrete and tiled around the toilet rather that on top of the tile so I'll NEVER be able to replace the toilet unless I rip up a mess of tile, grout and thinset. Really don't want to do that.
Thanks all!
Gary Swart
Yakima, WA
You're wrong about not being able to install a new modern toilet on that floor. Many people have this problem when a new floor has been laid and the flange set below the finished floor. Options include a repair ring on the flange, a thicker wax ring, and stacked wax rings.
ShawnN
Arizona
Some toilets have a wider base that would cover the old footprint.
Take a look at the footprint of Toto Eco Soiree.
https://terrylove.com/pdf/ms964214cefg.pdf
Now that might work. My main concern was covering that old footprint. I was already aware of flange extensions which I will more than likely have to use with this install. THANK YOU.
Eco Guinevere https://terrylove.com/pdf/ms974224cefg.pdf would be even bigger at the base, but you are unlikely to need that extra.
There are others.
The Unifit system lets you connect to the flange with the toilet not yet in place. That can let you see what is going on, and to shape wax with no danger that you will stress the wax as you lower the toilet into place on the adapter.
The old Briggs bowls had very small footprints. It's very likely that many of the new bowls will cover the old footprint. Most of the TOTO bowls would cover and also many of the new Kohler bowls.
ShawnN
Arizona
Will definitely check into the Kohler bowls. The Toto Eco Soiree is a bit out of my price range!
Soiree is not cheap, but it does sell for less than list.
Spend some time documenting the existing footprint, and compare that with that of prospective toilets. Maybe a Drake II would cover the area.
If you search a bit, you can get a Toto toilet for a lot less than the 'suggested' list price. If you check Terry's store, you can get an idea of the kind of price you should be able to find locally if you search around. The Drake is a very solid, if maybe plain, design that just works. You do pay for more 'style' and for some of the exotic colors (black is really expensive compared to white, for example, on the same toilet).
