Adjusting copper drain
UrbanNest
montreal, canada
Hello,
I hope I will explain it clearly :)
I have to change the location of a kitchen sink which will require the pipe draining into the vertical drain to be moved. The vertical drain is copper and is in the wall. We can access it by removing the gyps and insulation.
My questions is whether it would be easy for a plumber to make the adjustment considering that it is copper and its location. I've attached a picture to help make it clearer.
Thank you!!!
Jonathan
