And I thought I've answered any questions have been asked I don't know everything
Casing diameter? What is it you don't know-- how to measure the casing diameter, or why that might matter?
A. To clean existing pipes, you could use a pump to pump cleaning solution thru the pipes, thru a cartridge filter and back into the the pipes. Cleaning solution? Dunno... does that matter at this point?
B. Filtering out future sediment-- I would use a cartridge filter, with a means to bypass a clogged filter, or at least keep an extra o-ring on hand.
C. Precharged Pressure tank flush (Maybe annually, but you might try more frequently):
1. Connect a hose to the sediment drain valve, and run that to where you plan to drain the water. I suggest filtering the output through a cloth if you suspect the sediment may include sand.
2. Turn off the pump.
3. Open the drain valve, and let it drain until the water stops. It would be possibly interesting to watch the first water that comes out.
4. Close the valve, and turn the pump back on, and let pressure build.
5. Repeat steps 2, 3 and 4 a time or two.
Check air precharge annually is the usual suggestion. Air precharge is always done with water pressure zero. Combining that check with the flush makes sense.
