[Note: post below was edited 1 Nov to make clear that this is a submerged well pump]
Greetings. My friend has a 120VAC 1/2 HP submerged deep well pump (age unknown). Normal cut-on is 35 PSI, off at 55 PSI. It had been working well, but now, occasionally, he has very low water pressure (10 PSI, on the gauge near the pressure tank). When I feel the copper line from the pump there's some slight vibration like it is running. Also, the pipe feels >slightly< warm, like maybe the running-all-the-time pump is actually warming the water in the well valve casing a tiny bit. If we turn off the circuit breaker for the water pump and turn it back on, the pump recovers and pumps normally (35-55 PSI). It seems to refill the tank just as fast as you'd expect.
Any ideas what is going on? Do pumps that are near the end of their life die like this (mine never have)? My only theory is that maybe the circuit breaker (or a connection somewhere) isn't providing full voltage/amperage to the pump. The breaker would be suspect #1, because when we reset it, the pump works (for a day or so).
Just change out the breaker? Try something else? Get ready to call someone to swap out the pump?
Thanks for any assistance.
Mark
Mark
