Reader Review
Comments by readers
Hi Terry,
Thanks for taking the time to create such an informative web site.
We are working on a home addition which when complete will replace our 1949 bathroom with 2 bathrooms. We had already decided we wanted an ADA toilet in the master bath. When my toilet with the tank bolted on the wall continued leaking (into bowl recently even after replacement of the ball, I decide to go ahead & purchase one of the new toilets for the addition & get it installed in the old bath & then just move it into addition later. After research including your site & the MAP tests, I narrowed my choices down to Drake or Ultra-Max. My wife wanted the one piece UM instead of the 2 piece Drake so I shelled out the extra $ for it. When I went to order from the wholesaler, they informed me that Toto was in the midst of switching from 1.6 to 1.28 gal flush models so I decided to go ahead & purchase both toilets while I could still get the 1.6g model. The old cast iron toilet flange is well over ½” above the floor, not allowing the toilet to sit on the floor when on the flange so I had a friend who makes Corion countertops cut out a piece of ½” Corion from a template for the toilet to sit on. Got the ADA model on & all hooked up. Works great. Now I just have to fix up the wall where the tank was bolted & get the addition finished. This thing flushes really fast & is a little noisy at the end of the flush (when it sucks the air down) for middle of the night flushes, but we have yet to have to flush twice. My wife is VERY happy, & the water bill should be back down next month as a result of the replacement.
I was also wondering if you have any idea on any uses for the antique that I removed or who may want it? Round bowl with a huge wall mounted tank & chrome pipe in between. Flush valve needs replacing but I knew I couldn’t use one of the plastic ones since the threads don’t go to the end of the flush valve on those to be able to affix the nut to hold the chrome pipe.
Anyways, I just wanted to drop you a line to say thank you for the advice & the web site.
Best wishes,
E Hobbs,
Corapeake, NC
Best wishes,
E Hobbs,
Corapeake, NC
