Cadet PRO Elongated Toilet 10" Rough-In 1.6gpf
American Standard Cadet Pro 10" Rough, 215CB.004
Fluidmaster fill valve and 3" flush valve.
Elongated bowl with standard height. 15"
American Standard bowl
The Pro Version
Cadet Pro tank
Red rubber tank to bowl gaseket on the left. The tubes on the right are for installing the tank bolts.
Under the bowl rim
WJcandee
Wise One
New York, NY
What's that white male-urination-appendage-looking thing in the flush hole in the bottom of the tank? Looking at your photo underneath the tank. (I tried to say "*****", but you see what happens.)
WJcandee
Wise One
New York, NY
I have no idea what you are trying to say here :)
Huh?
Ah. Okay, look at the first photo of post #2, which you label as "Cadet Pro Tank". It's a shot from the bottom of the tank looking up. The flush hole has something roundish in it. It is white. It has a maybe 1/4" to 1/2" hole in it. [It is proportional to a schlong -- that was my point.] I'm wondering what that is.
In thinking about it, I realize that the flapper has likely already been installed and this may be the bottom of the flapper, like a round ball with a hole in it. However, the flapper is red and this is white. Does the PRO have a red flapper with a white plastic insert, or is that something else?
Rorschach? :)
What is that big red plastic thing in the next picture down. Is that a wrench to give a better grip on the big white nut under the tank?
The bottom of the tank thingie?
That is the flapper.
Many flappers have a hole on the bottom. Maybe all but a few.
Also many other things may have holes. I'm thinking thata Swiss Cheese has holes, and so can wood with termites have holes in it.
Also strainers have holes. If I count the holes in my shirt I count four, except if I look at a button down shirt, and then I count 13.
The red thing, that's the tank to bowl gasket.
