I've been looking at this dehumidifier:
Frigidaire FAD704DWD High 70 Pints Daily Output SpaceWise Portable Dehumidifier.
Specs say it pulls 7.5 amps.
I have a couple of questions.
Do these portable humidifiers heat up the room appreciably?
Are they noisy?
Thanks.
(This is a bit late on the response but...)
The amount of heating depends on the amount of moisture it's pulling from the air. The heat of vaporization of water is 970 BTU/lb, (approximately one pint, depending on temperature.) There is the additional heat-adder of the compressor motor, figure on at least 11oo-1300 BTU/pint going as sensible heat into the room, depending on the room's humidity. As the humidity drops, the efficiency drops, increasing the total BTU/pint.
If it's pulling two pints per hour it's something like 2500 BTU/hr of sensible heat into the room, which is a substantial heat rate- the temperature will rise pretty quickly. (That is is at typical design heating load of a small bedroom when it's 0F outdoors, 68F indoors.)
If it's only pulling half a pint per hour it's the equivalent to the amount of heat- a somewhat active walking/standing human is adding to the room.
Inside my house, the humidity is 85% today, and last summer it would climb to 90%. I'm just trying to stay comfortable. No a/c... yet.
Without the temperature to which it's relative, the % relative humidity is a somewhat meaningless number.
A reading of 90%RH @ 70F is the same
absolute humidity as 65%RH @ 80F. That level of humidity feels clammy to most people at 70F, but only somewhat sticky (not necessarily terrible) to most people at 8oF.
In-between those temperatures comfort at that humidity level varies person to person- it's a bit high, but not swampy.
