What would cause melted element in EHWT
speeder
British Columbia
I have had 3 melted electric element in a 6 year old electric hot water tank in the last 5 months.
Problem started when I flushed the hot water tank 5 months ago. Problems started right away. Tripped breaker then no hot water... Element melted. Happened again 2 months later .. Then just happened again.
It's a 40 gallon tank with 2 3000W elements running non simultaneous.
Any thoughts or time for a new tank?
Phog
Active Member
Rochester NY
Have both the upper & lower elements blown? Or is it the same element melting every time?
speeder
British Columbia
When I looked in through the element hole, the anode was basically gone at the bottom but the top was still there but pimply all over.
Possible to just change the anode?
Phog
Active Member
Rochester NY
The anode just slows down the tank corrosion rate. It doesn't have anything to do with the electrical componentry, and won't fix this issue. I don't know why your elements are blowing, I'm sorry.
speeder
British Columbia
Ah ok. Thanks for the advice I will look for those. If you can provide any links to good ones, will be much appreciated.
Master Plumber Mark
www.weilhammerplumbing.com
Is it just the ones that are longer and bent back onto itself? Are copper ones better?
Just ask someone when you go there... the copper ones are dog dirt cheap and burn out fast,
the double looped ones say that they are SS and cost much more...simply ask someone
very simple , very easy
DonL
Houston, TX
Silly question. Did you turn off power before draining the tank ?
Or have any chance of loosing water pressure ?
The heating elements are water cooled.
Good Luck.
speeder
British Columbia
Good Luck.
YES!! haha. not silly question. I did fill it up and ran the hot water tap for a while before I turned the breaker back on.
I don't think there's a chance of losing water pressure.
