Kodidavis29
Hi guys new here but am torn about a decision to upgrade to a tankless water heater 11gpm Westinghouse model sold at the box stores and online. Or just add another 40galon water heater in series to my exsisting 40galon.
My setup is a custom jetted shower just built with 4 jets 2.5gpm each a rainfall shower head at 2.5gpm a standard shower head at 2.0gpm and a handheld shower at 2.5gpm.
They all have separate valves so they typically won’t all be running but in the event they all do id be pulling 17gpm.
Running it now with just my 40 gallon I get about 6-8 min shower.
Every where I look online they talk about the water heater having enough gpm to power your setup but they seem to forget that the thermostatic valve in the shower pulls cold water into it as well I would assume you need to know the ratio to figure out exactly what the gpm of hot water you need actually is.
My biggest question is will 11gpm work if I go tankless also I’m in Michigan so my rise is high about 40degrees incoming so specs on this claim to only be 5gpm at that high of a rise. My thought was to keep the old tank and use it as a point for the water to atleast get to room temp prior to going through the tankless. (But what’s the point of tankless then)
Energy usage isn’t a huge concern but always something that can help change a decision.
So what do you guys think add another tank or go tankless all together?
