What size sediment screen for my deep well pump?
Timbuktu
PalmSprings SCal
One of these days my deep well submersable will fail and require a "well man" to pull'er up.
So i can be prepared for that day I should be researching now ,the kind of sediment filter that id have them replace the current one with. Thats assuming i have a "mesh size " choice .
Of course theres no way of knowing what smaller size i need unless I know whats on it now.
You know,I did save some sand that came up a few days ago,so i could take that sample into a dealer who could size the mesh using my sand sample. right?
Timbuktu
PalmSprings SCal
I assume there is supposed to be a sort of screen filter where the water first enters the well pipe down below.
Is there a place online you may know of where I can see whats available ?
or.. Is it better just to wait until the pump fails and has to be pulled up. Then whoever i call out to pull up the pump will be able to recommend a new filter screen then.?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Good well casing with screen or perfs should be the screen that keeps sand out of the well. But if it pumps sand, then you have to filter above ground. Lakos makes a seperator that fits on the pump. But you will need some open hole below the pump for it to drop the sand into.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Is this a mud or rock bore? A rock bore would not use screened casing. If a rock bore, it might be top fed so putting a sleeve on the pump may help.
If it is a mud bore, the well may need some further development by heavy over-pumping. That said, some wells may never clear up and so a dole valve and in-line filters might be the only option.
Timbuktu
PalmSprings SCal
I have no idea. Im in decomposed granite. High desert mountains. Never seen mud here,plenty of rock and sand.
lebatard
New York
I agreed with the 2 screen idea. First use the more coarse screen as a first layer of protection and behind that, use a very fine wire mesh. Try something like a 100 x 100 stainless steel wire mesh that might be found here:
http://www.bwire.com/
These 2 layers of screening and filtration should be enough to keep both large and small sediment from causing this catastrophe that you are preparing for. Cross your fingers and hope you have a lot of time before this occurs.
