ShadowAviator
I am building a small house. (shedhome) The individual fixtures are not very far (15ft-20ft). The water heater, softener, manifold are all right by where the main supply line comes up into the building.
I believe the main supply line is 1" HDPE (I need to double check). I want the main line to adapt to PEX, then through a softener before teeing off, one to water heater and one to the water manifold. The hot from water heater will also go to manifold. From the manifold, I was gonna run 1/2" PEX to all fixtures.
My question is, can I adapt down to 3/4" PEX for the main lines, or should I try to keep in 1" for as long as I can?
My worry is maintaining enough flow. Its my understanding that PEX-A would be okay with expansion fittings. But my local stores carry PEX-B (Viega), so I was gonna go with that and crimp fittings.
Also what would be the best way to adapt from the HDPE pipe to PEX? Does one type of fitting work better than the other?
I have been trying read through other threads for answers, but wanted to double check for my situation.
Edit: I forgot to mention, the supply line comes from the well. This is out in the country on a farm. I don’t know if that changes anything.
